  3. Best way to add "charging pads" to PCB/Case Assembly
  • Subscribers 166
  • Views 1048
opleininw
opleininw over 5 years ago
Hi everyone! I'm working on a small battery powered PCB which will fit inside a small plastic "hockey puck" container. A number of these "pucks" will be sold together with a "charging doc" which will store and charge the pucks when not in use.
I'm trying to work out the best way to charge the battery. I'm thinking of having metal "pads" on the rr.com puck that pass through the puck's plastic shell and then make contact with the PCB on the inside, and having a similar system on the charging dock. I'm thinking of having SMD "contact sprints" mounted to the underside of the PCB and have these mate against metal pins that protrude through the puck, but it's the later of which I'm struggling to find. For a visual, think about "restaurant pagers" and how they charge.
  • RFinley
    RFinley over 5 years ago
    Everyone uses PogoPins for these applications on the charger device that contacts pads on the wearable device.
