  3. Replaying scripts multiple times
  • Views 14976
Mikewr7
Mikewr7 over 6 years ago
At one time I had a script for rotating (text/parts). It was setup to rotate 90 degrees. Each time I replayed the script it would rotate another 90 degrees. Now when I replay the script it will only rotate 90 degrees once. How do I set up a script to replay each time I run it? Thanks!
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    I think your script might be using 'angle 90', which you want to change to 'iangle 90'
  • Mikewr7
    Mikewr7 over 6 years ago in reply to DavidJHutchins
    Thanks David! As it turns out it was not a script file I was using but an alias. I just set it to "iangle 90" I had forgotten this because I was on a different tool the last year and now I'm back on the best. ;-)
  • CadAce2K
    CadAce2K over 6 years ago
    alias F2 'rotate 90'
    Select the component/text ; hit F2 and start rotating.
