  3. Agile users
  • Subscribers 166
  • Views 14794
Agile users
TiBo
TiBo over 5 years ago
I am current looking a software that uploads files and BOM into Agile. We use OrCADs for schematic capture.
We are having a hard time to find the software that would do that. We have perception EDAConnector right now and they have discontinued technical support it since last year.
I am looking forward to hear from you.
TiBo
  • CadAce2K
    CadAce2K over 5 years ago
    This is DEFINITELY THE WRONG forum to post, but then again you're not the 1st puib to do it, so I'll give a quick answer. Your CM person in charge of Agile can easily create a script to read in the Orcad BOM. If you don't have one, or he/she is incapable... too bad. It was easy at my last company.
    • Vote Up -2 Vote Down
  • Wild
    Wild over 5 years ago in reply to CadAce2K
    Which forum would you suggest this user post a Capture question to?  This would be helpful for me and others.
    Please note many of the folks look for guidance and help, so please stop the yelling.
    Kind Regards,
    Wild
    • Vote Up +2 Vote Down
  • CadAce2K
    CadAce2K over 5 years ago in reply to Wild
    I'm not sure there is a "Cadence forum" for an Agile program issue, and this is certainly an Agile issue. (Not yelling - emphasizing...) And as I mentioned before, the Agile CM can set this up. From what I remember, it's not a hard task for them and didn't present a problem in capture creating what Agile needs. But it's an Agile process to import the capture BOM. Good day.
  • djs42
    djs42 over 5 years ago
    Typically PLM / CM tools import BOMs in .csv or .xls format. You'll need to check with your Agile folks to determine which data fields are required by that system to determine correct data mapping. Design files, drawings, etc. are normally imported individually and attached to an Item Master record in your PLM / CM system. For this you will need to determine what the standard data / drawing format your PLM / CM system requires (eg. PDF, ZIP, DWG) before generating files from your design tool for import.
  • TiBo
    TiBo over 5 years ago in reply to djs42
    Hi all,
    Thank for your help and I didn't mean to offence anyone.
    I think, I got enough info to move on and come up with something that will work for our company.
    Best regards,
    TiBo
