  3. OrCAD Capture CIS - CIP database part DRC error
  • Views 9136
mwso
mwso over 5 years ago
When running a DRC in capture for a schematic, all of my database parts placed from CIP return ORCAP-2434.
For instance from the CIP starter library I placed a molex connector (P/N 26-60-4030)
WARNING(ORCAP-2434): Footprint 'MOLEX_41791-3' specified in PCB Footprint for instance 'P3' is missing. Ensure 'MOLEX_41791-3' is in the library path.
My footprint path is set in my Capture.ini file, so I am unsure how to resolve this issue. I also have not found any information online for ORCAP-2434.
  • RFinley
    RFinley over 5 years ago
    The footprint path in your Capture.INI file is only used for footprint preview when placing CIS parts.
    You need to verify your library path inside the pcb layout tool, >Setup >User Preferences >Paths >Library >padpath and >psmpath need to be set.
  • mwso
    mwso over 5 years ago in reply to RFinley
    I added the path to my library in the pcb layout tool but the Online DRCs are still present. Is there something I need to do after setting the path?
  • RFinley
    RFinley over 5 years ago in reply to mwso
    A quick test:
    Allegro/Orcad, try placing your symbol as a mechanical part.
    >Place >Manually
    (pulldown menu right under Placement List tab)  > Package Symbols
    If this particular footprint does not appear in the list (check a box to place a mechanical instance of this symbol), then a common mistake with me is an old-fashioned typo in the symbol name relative to what I called it in CIS/CIP.  Or, there is a typo in the library search path.
