  3. Circular Move, for a particular pins
  • Subscribers 166
  • Views 13157
Ramelb
Ramelb over 5 years ago
Good Day Engineers,
Hello engineers, I was having difficulty on how can I move pins of the Relay Teledyne, the only given dimension are the diameter 200 mils and the angle 36+- 3degrees. How can I move the pins in a way that is having a
36degree  in circular manner. Thank you.
  • steve
    steve over 5 years ago
    Place one pin (say pin 10) then use Edit - Copy, set the Options pane to Polar array and copy the pins based on the angle etc you require.
