  3. Resistor DIP 4 A-D from Discrete library
  • Subscribers 166
  • Views 13322
Sabev
Sabev over 5 years ago
I need some help with using Resistor DIP 4 A-D part from Discrete library. I have to use the package with the 4 resistors but when I create a netlist it creates 4 separate components (4 packages of 4 resistors each). I'd like to have one package with 4 resistors RA, RB, RC and RD so I can place it on the PCB. Some help with be much appreciated.
  • AvengerThanos
    AvengerThanos over 5 years ago
    Create a footprint with 8 pins and provide the same name in all the parts of the resistor then you will be able to place 4 parts resistor as a single package resistor in pcb
