  3. How to change the layer of a ground plane
  • Subscribers 168
  • Views 16730
vtolentino
vtolentino over 5 years ago
I was trying to change the layer of a ground plane, through Shape -> Select Shape ->Active Class and Subclass but it does not seem to work. Am I missing something here?
Thank you.
  • avant
    avant over 5 years ago
    Use edit / zcopy to copy the shape to another layer. Use the option tab to select new layer.
  • CadAce2K
    CadAce2K over 5 years ago
    Hover over it with 'Shapes' in the find filter; RMB; Change to Layer ; click on whatever layer you want to go to. It won't work in Shape/Select Shape Mode.
  • Zenidin
    Zenidin over 5 years ago
    Thanks for this topic I also searched for the same topic sitting in my property in Barcelona all day long. I just used "Select Shape Mode" and it worked!
