  3. Create NetList with TCL with DiallogControl .XML file
  • Views 13509
RkNg
RkNg over 5 years ago
Morning everyone,
I have an issue that over my understanding.
1. First, I go to Toos/Create Netlist, and input my customization value (in Other/Part Value, and Other/PCB Footprint properties).
2. Press OK (and i received and TCL command like this: Menu "Tools::Create Netlist" | DialogBox  "OK" "C:/Users/RkNG/AppData/Local/Temp/CAPTURELOG/Sat_Mar_28_19_22_07_2020/Other_6.xml")
3. The Netlist i received now is perfect as my setting in step 1.
Now, I want to create another Netlist with the same format, but I reused the "command above" (step 2). I also receive an Netlist with "default setting" not the same as my setting in Step 1 (although my setting is shown exactly the .xml above. "..../Other_6.xml".
So my question is, how to set/change the default value for "Part Value and PCB Footprint" in Tools/Create Netlist.
Please enlighten my.
Thank you very much for your help.
