  3. Allegro Static IR drop dialog box does not appear
  • Views 14377
rdawson16
rdawson16 over 5 years ago
First time I have tried this, I am reading the manual PCB SI User Guide, chapter 9 Analyzing for static IR drop
I am on 16.3, license PCB SI XL.
Either command line irdrop, or menu Analyze -> IR Drop, the GUI analysis dialog box does not appear.
The command window shows its running the skill for the GUI:
Loading powerquest.cxt
Loading axlcore.cxt
Loading skillExt.cxt
but it does not launch the dialog box.
Suggestions?
Randy
  • steve
    steve over 5 years ago
    Check your version. Not sure when the IR drop testing became available but might not have been 16.3 which was a long time ago. The latest release is 17.4.
  • rdawson16
    rdawson16 over 5 years ago in reply to steve
    It's n in the 16.2  manual, Analyzing for IR Drop ch 9, page 361.
    And the code is there, see from above, it recognizes irdrop from the command line too, and IR drop is in the Analyze pull down menu.
    Thanks Steve,
    Randy
  • steve
    steve over 5 years ago in reply to rdawson16
    Hi Randy OK just make sure you have the latest hotfix for 16.3 and see if that helps.
