  3. Is it possible to delete an only one rastnet instead "delete...
  • Subscribers 166
  • Views 2135
Is it possible to delete an only one rastnet instead "delete all" in allegro 16.6?
EuSV
EuSV over 5 years ago
Hi, I've seen that allegro 16.6 has an option that allows us to delete all rastnets at a time. I'm wondering if it is possible to selecting one rastnet and delete it.
I was trying to select one of them, but when I click "delete" it stills being there.
I have checked "rastnets" on the "find" objects tab.
  • Dennisco
    Dennisco over 5 years ago
    Hi EuSV,
    You don't delete rats, you display them or blank them.
    Menu:
    Display/Show Rats/Net   (this will show the rats net)   The command on the command line is:  rats net
    Display/Blank Rats/Nets  (This will Blank the rats net)  The Command on the command line is:  unrats net
    For me this is to much work to track down these commands in a menu structure.
    Getting familiar with the ENV file and making custom keyboard commands can be a real time saver.
    I use Keyboard commands and I setup an alias in the ENV file,
    Here are my alias key commands that I use in the ENV file for displaying and blanking rats (the # is a comment for my reference)
    alias ur unrats all # unrats nest all
    alias rn rats net # ratsnest by signal name
    alias br unrats net # Blank Rats net
    alias rc rats component # ratsnest component
    alias urc unrats component # un-ratsnest component
    Hope this helps.
    Dennis
