  3. Error: CMFBC-1 The schematic and the layout constraints...
  • Subscribers 166
  • Views 13940
Error: CMFBC-1 The schematic and the layout constraints were not synchronized
CC24
CC24 over 5 years ago
Hi, I am in the middle of a design and had no problem going back and forth between schematics and layout. Now I am getting the error message below. I am using Cadence 17.2.
ERROR: Layout database has probably been reverted to an earlier version than that, which was used in the latest flow or the schematic database was synchronized with another board.
The basecopy file generated by the last back-to-front flow not found.
Error: CMFBC-1: The schematic and the layout constraints were not synchronized as the changes done since the last sync up could not be reconciled. Syncing the current version of the schematic or layout databases with a previous version would result in this issue. The  constraint difference report is displayed.
Continuing with "changes-only" processing may result in incorrect constraint updates.
Thanks for your input
Claudia
  • AvengerThanos
    AvengerThanos over 5 years ago
    I think this may give you an idea about constraint manager https://community.cadence.com/cadence_technology_forums/f/pcb-design/43976/capture-constraint-man-anger
    The error states earlier and the latest version. Which version have you been using 17.2 and 17.4 both
