  3. Passing Part Number from Capture
  • Subscribers 162
  • Views 15159
archive over 20 years ago
Our company uses a Part Number centric scheme for using parts. All parts are placed in Capture according to their Part Numbers. I need to pass this Part Number field from Capture to Allegro so that I can make a Pick and Place report that has the Part Number field populated. I have check the Orcad Capture allegro.cfg file and have set PART_NUMBER=YES and still can't get the attribute to passover during netlisting. Any ideas? Anything that I am missing?
Thomas Miller
DakoCytomation, Inc.
Originally posted in cdnusers.org by thomas.miller@dakocytomation.com
    You need to set up one more feature in Allegro to get this to work.
    Go to the menu SETUP->PROPERTY DEFINITIONS and add a new one that you're importing and Allegro will recognize it.
    Originally posted in cdnusers.org by redwire
    This is correct, however PART_NUMBER is a reserved field in Allegro.
    I found out where my error was and am now able to pass the PART_NUMBER value from Orcad to Allegro. I had inadvertantly added PART_NUMBER=True into two sections of my allegro.cfg file and it was creating a conflict. Once I removed the second entry, everything worked fine.
    Thanks!
