  3. SPECCTRA: matched length THROUGH series resistors
  • Views 13450
archive over 20 years ago
I need to match lengths for signals from the microprocessor to the SDDRAM chips. Unfortunately, some signals go through series resistors.
I have 3 senarios:
1) Micro -------------------------> SDRAM
2) Micro --> resistor ------------> SDRAM
I know how to set up a class for senario #1, and to match the routing length. How do you set up Specctra to match senario #2 to #1, i.e. the total length from the micro to the SDRAM is equal regardless if it goes through a resistor or not?
Any help or tips are welcome!
thanks in advance, claudio
Originally posted in cdnusers.org by artaflex
    Hi
    I had not faced like this problem !
    But as per my assumption
    Assign resistor spice model to component. Then define X net length.
    Hope it will work.
    Originally posted in cdnusers.org by naren_thesia
