  3. PCAD to Allegro
  • Replies 8
  • Views 16647
PCAD to Allegro
archive over 20 years ago
I am trying to convert a PCAD 2002 file to
Allegro. I have not had any sucess with the File>Export>PDIF function.
What do I need to do?
It does not make a file where I tell it, only an error text file.
Daniel
Originally posted in cdnusers.org by nardian2003
    archive over 19 years ago
    I haven't had any problems exporting a pdif from Pcad, but I am having problems with the import pcad to allegro. (version 15)
    It seems to load the file at a 10x the normal size.
    For example, a header with 100 mil pitch is loaded as 1000mil pitch.
    Curious........
    Originally posted in cdnusers.org by pitbull107
    try to modify the unit in pdf file from
    {DBunit "MIL"}
    to
    {DBunit "CENTIMIL"}
    Originally posted in cdnusers.org by erictc
    Unless I am missing something, I have only two choices of units: mils or mm (radio buttons in the configure menu of Pcad)
    I tried the mm units and the same thing happened. Any other ideas?
    that's why i say "in pdf file".
    because the pcad dos and windows is differ,
    Pcadwin2Allegrojpg.doc
    Beauty! That works! Thanks!
