  3. Searchable PDF in Windows(Bottom Side)
  • Replies 7
  • Subscribers 162
  • Views 5696
archive over 20 years ago
Anybody knows how to create searchable PDF for Bottom side mirrored view.(Readable)
Originally posted in cdnusers.org by rajendd
    Hopefully you've been able to fix this, but if not, here's what I do to get searchable bottom-side mirrored/readable text in .PDF.
    I use Acrobat 7.x.
    In Allegro, I go to the plot setup using file->plot set-up. I check the mirrored box. In the Windows tab, ensure that the non-vectorized text box is checked. Then file->plot and selecting my .PDF writer yeilds right-reading searchable .PDFs.
    Bill
    Originally posted in cdnusers.org by bill_lawson@desilaw.com
    That is a good method of working around the problem.
    However it seems there is an opportunity for an Allegro enhancement here. If "Create Detail" retained text as text in the detail instead of line segments, it would be easy to create mirrored view of the bottom side that would produce a pdf with searchable text.
    Do other users see value in this enhancement request? I would be surprised if this has not already been requested thru an SR.
    Randy
    Originally posted in cdnusers.org by rb
    Hi Randy,
    The method Bill describes above certainly works quite well.
    I've not as yet seen the specfic enhancement request you
    mention above. I would encourage you to contact Cadence
    Support so we can either add your company to an existing
    enhancement request PCR, or file a new PCR as needed.
    Jerry
    Originally posted in cdnusers.org by geraldg
    For top side is fine.But for Bottom side I want a PDF file with mirror image.If I give mirror it is coming as non searchable.Thats the problem.
