  3. swap code
  • Subscribers 162
  • Views 18683
swap code
archive over 20 years ago
Hello all,
i am having Allegro pcb editor 15.2. i want to swap the pins of an ic or resistor but when i click over pin it says "pin not swapable swap code is zero"
i don't know where to add this swap code and make any pin wsapable the online documentation is not sufficient to understand so pls tell me the simple steps to follow and make pin swapable.
pls do reply
allen
Originally posted in cdnusers.org by allen
    The swap must be define in you schematic or netlist.
    What id your entry?(concept, orcad capture, netlist,...)
    Originally posted in cdnusers.org by jcteyssier
    where to define this swap code in capture
    pls explain in details
    currently it is giving error as "swap code is zero"
    This is done in the schematic part symbol editor (i.e.OrCad).
    1.Bring up the part for editing (usually from within the library).
    2.Select "Pacakge" from the "view" menu.
    3.Select "Properties" from the "edit" menu.
    4. The column labeled "pin group" is actually the pin swap id. Use numbers from "1" up. Pins with the same number will we swappable with eachother.
    On homogenous multipart parts like a quad AND gate, the two AND inputs of all four gates will be 1, as each gate is a separate part.
    The help files sort of cover this. Look in the capture help index for "pin swapping for allegro"
    Originally posted in cdnusers.org by lcotten
    It is documented in help:
    search pin_group
    ok cool got it.
    i tried with help file searching pin swap but didn't got any thing but the procedure you given worked...!
    thanks
