  3. artwork
  • Views 13131
artwork
archive over 19 years ago
hello all,
In allegro pcb editor under Manufacture(tool)--Artwork--Genrate parameter--there is something called SUPPRESS under that there is leading,trailing zeros and equal co ordinate what does it means and what is it's use.
can any one suggest me..?
thanks for your reply in advanced....!
allen
Originally posted in cdnusers.org by allen
    All is documented in help:
    Suppress equal coordinate: if you have several objects that have same coordinate and that just one can describe all -or several- of them, then just one needed is output.
    Suppress leading/trailling zeroes:
    You specifies a format for coordinates: say 2.4 in inch so 10 mils will be output as "000010".
    If leading is checked, output "10"
    If tarilling is checked, output "00001"
    This is to minimize gerber file size
    I check "leading" and "equal", this is he default behavior.
    Originally posted in cdnusers.org by jcteyssier
