  3. Assign Value Property to discrete components
  • Subscribers 163
  • Views 14574
archive over 20 years ago
Hi, I want to ask that how can i assign propety value to discrete components. My case is that when I assign Property "$value" to symbol and create its schematic and export the design there is no value displayed in pcb. Please send answer to the email add: mohatirf@yahoo.com
I am waiting for answer thank you.
Originally posted in cdnusers.org by mohsatirf
    archive over 19 years ago
    What schematic front-end do you use?
    . Concept
    or
    . Capture
    or
    . DxDesigner?
    I know the way to show the value using Concept. Should show using Capture too. SHOW ELEMENT//pick a component In the Show Element window it will give the value and the schematic page it's on.
    Good day.
    Originally posted in cdnusers.org by cadpro2k
    I suggest that you post this question on the PCB Design Forum as it is not Skill related.
    Originally posted in cdnusers.org by Dave Elder
    Please explain further:
    What schematic capture tool are you using?
    How do you wish to "see" the property in Allegro?
    Mike
    Originally posted in cdnusers.org by AshCan
    Hi
    If u want to display the value property in Allegro Editor
    Check this out
    Display -> Color/Visibility
    Group:(Select COMPONENTS from pull-down menu) and play around
    --nanda
    Originally posted in cdnusers.org by nanda
