  3. IDF Export to Solidworks (Holes not appearing)
  • Views 12809
JasonSn
JasonSn over 5 years ago
I've been generating IDF and PTC for Solidworks import but plates/non-plated holes are not importing. I've tried with/without filter, and version 2.0/3.0.
I have been having trouble with both pins and vias (I have only included the vias as a test). If I open the emn or ldf, I can see them defined.
Could "ECAD" designation versus "PLACED" be an issue? I don't know how that is determined
MEC_HOLE0320CU0800_CL6 MEC_HOLE0320CU0800 PH7
55.0000 194.2000 0.0000 0.000 TOP ECAD
I get the following warning, as well
WARNING: More than one place bound shape defines the outline of MEC_HOLE0320CU0800_CL6.
  An overall place bounding box was exported instead.
vias -->
.DRILLED_HOLES
0.2500 -36.1250 34.6250 PTH BOARD
0.2500 -35.2274 34.5000 PTH BOARD
