  3. Via on Pad Designs- Edge of Via to Edge of Pad Spacing
  • Subscribers 163
  • Views 2739
archive over 21 years ago
Anyone have a good work around for checking edge of via to edge of pin spacing for via-on-pad designs? (I need to make sure the via lands within the pin and that it falls within the pad by a specified distance.)
Originally posted in cdnusers.org by leahmm
    I cannot think of a way on top of my head, but if you are familiar with Allegro Skill then you should be able to write a function that reports/checks exactly what you are looking for.
    Message was edited by: Andy_Kulik
    Originally posted in cdnusers.org by Andy_Kulik
    Not sure if you could do it in skill but you could make a export to a dxf file and bring it into a cad package such as autocad and measure from quad of via to the edge of the pad. Its a little bit of work but should give you the answer.
    Originally posted in cdnusers.org by Rick-J
    Draw a via keepout on the perimeter of the pads in the symbol drawing, create new symbol, and update the design with the new symbol. This will give you a visible DRC if the via pad is inside the narrow via k/o drawn around the pad perimeter.
    Originally posted in cdnusers.org by Dallas_Designer
    visual aid for my last post
