  3. Unable to click OK button under Setup - User preferences...
  • Subscribers 166
  • Views 1975
Unable to click OK button under Setup - User preferences, as tabs going beyond screen resolution
Micheal schenk
Micheal schenk over 5 years ago
I am using OrCAD PCB Professional and recently update with the hotfix. With the latest hotfix installed I am facing issues in selecting OK tabs under setup - user preferences.
I cannot update any .pad path, .psm path, or any features selected under User preferences as I am unable to hit on the OK button.
I tried varying screen resolution yet the issue remains the same.
Any help would be appreciated.
  • Christian H
    Christian H over 5 years ago
    I had the same problem, I fix it by changing the fontsize
    Add this to the ENV file and see if it helps “set fontsize = 10”
