  3. Running 17.2 and 17.4 on the same system.
  • Views 16060
Lennie
Lennie over 5 years ago
Can you run version 17.2 and 17.4 on the same system ?
  • steve
    steve over 5 years ago
    Yes - the install paths are different, C:\Cadence\SPB_17.2 and C:\Cadence\SPB_17.4. You have different icons and they will point to different locations of the exe's
  • Lennie
    Lennie over 5 years ago in reply to steve
    Do you still have to use the Cadence switch release program ?
    Are they completely independant or do they share settings ?
  • steve
    steve over 5 years ago in reply to Lennie
    No because it no longer requires the PATH variable. You can start 17.2 or 17.4 without issue. For schematic there are two separate folders %HOME%\cdssetup\OrCAD_Capture\17.2.0 and 17.4.0. This is for the capture.ini file. For PCB they use the same pcbenv folder (%HOME%\pcbenv) but there isn;t an issue with this. The PCB Footprints all stay at 17.2 unless you use some 17.4 technology in the footprint. Both compatible with each other. If you need to there is a Downrev from 17.4 to 17.2.
  • shuchen2
    shuchen2 over 5 years ago in reply to steve
    Could we somehow change the default version associated to .mcm or .brd files? it seems like changing the CDSROOT system variable does not help. Thanks!
  • RFinley
    RFinley over 5 years ago in reply to shuchen2
    I've always done that by selecting a BRD file, then  >OpenWith >Choose Another App.
    Don't forget to review the checkbox if you want to change the association with the filename extension.
    For reference, here are the paths.
    C:\Cadence\SPB_16.6\tools\pcb\bin\allegro.exe
    C:\Cadence\SPB_17.2\tools\bin\allegro.exe
    C:\Cadence\SPB_17.4\tools\bin\allegro.exe
