  3. STEP file generation
  • Subscribers 166
  • Views 17806
marekmat
marekmat over 5 years ago
Hello everyone.
I've finished my project and I want to generate a STEP file. I selected Export -> MCAD -> STEP... I pressed Export but I've gotten an error.
(SPMHGE-268): step out had errors, use Viewlog to review the log file.
The problem is, a Viewlog file is empty and I don't know what's going on. I have no DRC errors. I tried other settings but it didn't help. Could you help me?
  • Bixio
    Bixio over 5 years ago
    I'm using Allegro 17.2 S063: try File > Export > STEP then select the info you want to export
  • steve
    steve over 5 years ago
    First make sure that you are using the latest version of software so 17.2-2016 S068 or 17.4-2019 S007 (both available from http://support.cadence.com or Download Manager). If you have those it could be that the STEP models you have used are different units so try Setup - User Preferences - Interfaces - STEP and enable step_export_mixed_units.
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to steve
    View the board in 3D mode & you can find the export option there and you need to select .step format
