  3. Component offset is step file mapped PCB
  • Subscribers 166
  • Views 12319
ecycv71
ecycv71 over 5 years ago
I am facing an issue in the step file of the PCB. PCB step file got one component which is shifted from the original location supposed to be.
Attached is the image for reference
Pl help on this.
  • CadAce2K
    CadAce2K over 5 years ago
    Go into Setup/STEP package mapping; select the component you're having issues with an change some fo the X, Y, Z parameters and get it to line up with your footprint.
