  3. Via got deleted
  • Subscribers 166
  • Views 12056
Via got deleted
GK MN
GK MN over 5 years ago
Hello
I  selected  "all on " on find tab and deleted some portion of layout routing , but this action deleted all the Via's through out the board associated with power net  (GND ,VCC)
I didn't noticed this and did good progress in the layout , later I  saw just "CLINE" is there on fan-out , no via :( .
Is this a bug ? if its deleted due to selection of net in find tab  then cline also should delete !. Causing lot of rework  at the end .
Tool Version :17.20
Girish
  • steve
    steve over 5 years ago
    No bug, it's probably because you had nets enabled in the Find Pane.....
