  3. Drill Layer Pairs in Orcad Documentation Editor
  • Views 13052
BK2001
BK2001 over 5 years ago
The question is: how to get Documentation Editor to display drill layer pairs separately in a drill chart?
The drill I have now groups all the same diameter drills into one line and calls the Start and End layers both 0, so Layers 0-0.
In PCB Designer (the layer pairs are correct):
Has anyone else run into this and figured out how to correctly display Layer Pairs?
There should actually be 3 lines for 0.152mm drill, Through, L1-L2, Bottom-L2
TIA for any responses!
(would really like to get a forum for just Documentation Editor going, it's totally a diamond in the rough!)
  • BK2001
    Found that Tool Type Defenition is the fix for this:
