  3. Standard via structure - trace width
  • Subscribers 163
  • Views 1288
grigorybuden
grigorybuden over 5 years ago
Hi
I create "standard via structure"  for BGA fanout with trace width 0.2mm ( because I need not standard trace angle between pin and via).
But when I use create fanout command with radio button "standard via structure" - trace width NOT changing in according to my constraints, it stays 0.2mm as when I created via structure.
If I use create fanout command with radio button "via"  - trace width changing as I set in constraints.
Could you help me ???? Please !!!
