  3. Extracting voids and holes from negative shapes
  • Subscribers 163
  • Views 13192
archive over 21 years ago
Has anyone a good method to get voids and holes in negative shapes extracted in an extract file? Or a skill program which does that?
Originally posted in cdnusers.org by hrv_de
    You can extract voids using a command file similar to:
    GEOMETRY
    CLASS=""ETCH""
    SUBCLASS=""TOP""
    GRAPHIC_DATA_10=""VOID""
    GRAPHIC_DATA_1
    GRAPHIC_DATA_2
    END
    Refer to SourceLink solution 11095124 and/or the following link for additional extracta information (make sure you change ""C:/Cadence/PSD152"" to reflect your CDSROOT value):
    http://127.0.0.1:9000/C:/Cadence/PSD152/doc/algrodescmp/chap4.html#551869
    Exactly what are you trying to accomplish? There may be a better way to do it, but I hope this helps...
    Originally posted in cdnusers.org by Padmin
