  3. net_short
  • Subscribers 163
  • Views 13369
net_short
archive over 21 years ago
Has anyone had luck with shorting 2 planes? If I edit properties of clines/shapes, no net short property is available - only for vias can I do this successefully.
Originally posted in cdnusers.org by Roseann
    You need to assign the net_short property to a via or pin on each net and make sure the value of this property is 'netname1:netname2' (netnames separated by a colon). Then you should be able to connect the two planes together with additional etch or shape without DRCs (as long as the shape is assigned one of the two netnames).
    Originally posted in cdnusers.org by Padmin
