  3. Back drilling
  • Views 15021
Back drilling
archive over 20 years ago
I have a request to add an additional blind drill to many through hole pin locations on a connector. Is it possible to have 2 drill locations in the same location at the same time?
Originally posted in cdnusers.org by mariex
    I don't have any experience with back drilling, but since no one else has responded I'll try. You can either replace the through hole padstacks with blind padstacks or actually add a larger blind via defined on certain layers where the orginal padstack exists. So to answer your question, 'yes', but I would suggest contacting your fab house for details. You may also want to do a Google search for info about back drilling since it's a fairly new process. The following link may be a good start:
    Originally posted in cdnusers.org by Padmin
    http://listserv.ipc.org/scripts/wa.exe?A2=ind0310&L=designercouncil&T=0&F=&S=&P=3767
    Looks like the entire link didn't show up...
    This part should be at the beginning of the link above (or do a Google search).
    Sorry for the confusion.
    archive over 18 years ago
    I tried the link posted but it didn't work. Is there any other to specified the back drilling with Allegro, beside adding blind/burried vias?
    Originally posted in cdnusers.org by vinhly
    A new feature Back drilling is introduced in 15.7 (XL) might help you with more information.
    Good Luck,
    Raj.
    Originally posted in cdnusers.org by rajpcb
