  3. Propagation Delay Delta tolerance value in mils
  • Subscribers 163
  • Views 16523
GK MN
GK MN over 6 years ago
Hello
I usually set relative propagation delay  delta tolerance value in mils like “0:100mils” . One of the board I received for modification having it set in “ns” and the max length difference is 311mils , but still its shows green.
Just wanted to know “0.01ns means how much in mils ? ( I consider 140ps = 1000mils  , but this doesn’t match with the constraint set in CMGR)
I referred below two document  to get the value , but unable to correlate with CMGR value .
Document ref : https://www.flowcad.ch/cms/upload/ApplicationNotes/FlowCAD_AN_PCB_Constraining_Delay_Rules.pdf
Document ref : https://www.eetimes.com/meeting-timing-specs-on-boards-with-picoseconds-of-margin/
  • steve
    steve over 6 years ago
    You also have a pin delay value set (actual component pin to bond die) which is being taken into account. The calculation is being made based on propagation velocity factor (In CM Analyze - Analysis Modes - Electrical).
  • GK MN
    GK MN over 6 years ago in reply to steve
    Thanks Steve , You figure it out rightly. I missed the pin delay set in CMGR. Thanks once again
