  3. Error SMD pad not 'Either' layer for the 'Test SMT/blind...
  • Subscribers 163
  • Views 2538
Error SMD pad not 'Either' layer for the 'Test SMT/blind pad'
Leotordo
Leotordo over 5 years ago
 I'm working on a pcb revision of a master.
I received the database from the custumer and I don't know who designed the previous release.
Evertime I pick a new track on log windows appears this message
I tried on Design Parameter Editor but I can clear this error.
Some ideas?
Stefano
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I think it's the testprep setup, try the following commands:
    testprep prmed
    setwindow form.testprep_parameters
    FORM testprep_parameters test_pad_type SMT/Blind
    FORM testprep_parameters test_pad_type Either
    FORM testprep_parameters close
  • Leotordo
    Leotordo over 5 years ago in reply to DavidJHutchins
    I tried your commands
    Now there are some additional masseges
    (SPMHMF-152): SMD pad not 'Either' layer for the 'Test SMT/blind pad'.
    (SPMHMF-84): Detected an old 'Test SMT/blind pad' setting of C035S.
    (SPMHMF-86): The old setting(s) will not be visible in Testprep Parameters but will continue to be used until any new Padstack Selections are made.
    Stefano
