  3. Allegro fanout ratsnest connection to ground plane lost...
  • Subscribers 163
  • Views 15244
Allegro fanout ratsnest connection to ground plane lost after footprint symbol update, but tracks present
frank mpbc
frank mpbc over 5 years ago
In Allegro 17.2, I previously had fanout connections to a ground plane for a QFN footprint with no more unconnected ratsnestlines. I changed the footprint symbol and did an update. All over at the connections to the ground and 1.8V power planes I see ratsnests appearing between the pins as if the fanout connections were not there. However, the tracks are still there. (see the picture for pins 12 and 10) To make the ratsnests dissappear, I have to delete the tracks and fanout again.  How come? Can I reconnect the tracks automatically?
(I enabled the display design parameter to show the holes and have the ratsnest geometry set to straight)
  • RFinley
    RFinley over 5 years ago
    Select that net and make sure the cline segments and vias are still associated with the same net.  The cline segment touching pin 10 may have changed nets.
  • frank mpbc
    frank mpbc over 5 years ago in reply to RFinley
    "are still associated with the same net."
    How? With F4?
    Frank
  • RFinley
    RFinley over 5 years ago in reply to frank mpbc
    My approach:  make sure you are in etchedit mode, make sure nets are checked in the Find filter.  Just hover over it.
    If you hover over pin10, away from the cline segment, everything associated with that net will flash.   But, if you move to the right and hover over the cline segment, does the pin also flash or highlight?
  • steve
    steve over 5 years ago in reply to RFinley
    You can also try a Tools - Derive Connectivity, check the relevant options (first two) and click on OK. This sometimes happens if you have different database units and accuracy between footprints and the board.
