  3. new device CLASSes ? in capture.
  • Views 13986
Krissn
Krissn over 5 years ago
Hello there.
 I came across this message in capture:
CLASS property 'NONE' is illegal: 'Class must be one of IC, IO, DISCRETE, MECHANICAL, PLATING_BAR or DRIVER_CELL.'.
Of course is obvious that I can't assign NONE as class but I have never know about those classes:
What is their use?
Regards
Krissn
  • joma
    joma over 5 years ago
    a
  • joma
    I believe that the PLATING_BAR and DRIVER_CELL classes are for ic design. The only class that I use is MECHANICAL. If you create a pinless symbol
    in orcad or capture you can give it a refdes and use a pcb footprint that is a mechanical part (.dra .bsm) and use this class.
    This will part will appear in the bom and netlist and will appear in your list of components to place in your board.
    You need to make sure that your mechanical symbol only contains mechanical pins (no pin numbers allowed).
    Jim O'Mahony
  • Krissn
    Krissn over 5 years ago in reply to joma
    Thanks for answer Jim. I think it can be very useful for me.
    Thanks again
  • cdlep
    cdlep over 5 years ago in reply to joma
    Plating_Bar is also used for the plating bar for boards with finger connectors to be gold plated.  That keeps it out of sight for other tools and views when not needed to be seen.
