  3. Create shape from lines (compose shape?)
  • Views 18931
Leotordo
Leotordo over 5 years ago
 I've a board with complex outline
I loaded DXF file on an unused graphical layer.
I changed to Design Outline.
Now I've to z-copy this outline for package and route keepin, but z-copy needs a shape.
If I use the command Create Shape From Lines the shape is filled and I can get simple shape-outline.
What's wrong? I found on forum some thread about the command "Compose shape" but I think I was on older version of Orcad.
Any idea?
Stefano
  • steve
    steve over 5 years ago
    Design_Outline MUST also be a closed shape so make sure that's what you are using. Turn off the unused graphical layer. When you invoke the command check the Options Pane for class/subclass. if you pick Etch/Top it will create a shape. Make sure you pick the correct class/subclass and you should be fine.
  • Leotordo
    Hello
    I moved lines to board geometry silk screen
    All layer off except silk screen
    I run Creat Shape From Lines command and a Filled shape is created
  • steve
    steve over 5 years ago in reply to Leotordo
    I'm confused, compose the shape onto Board_Geometry / Design_outline which gives you an unfilled shape on that subclass then use Shape - ZCopy to contract that onto Route_Keepin / Package Keepin. Why are you going to Silkscsreen_Top ?
  • Leotordo
    Leotordo over 5 years ago in reply to steve
    sorry for my english
    I don't compose the shape. I import the outline from DXF to board geometry Design outline.
    If I try with Z-Copy doesn't work because del outline isn't a closed polygon
    Stefano
  • steve
    No worries, Ok so import the DXF to a dummy layer (Board_Geometry / Assembly_Details). One it's there use Shape Create Shape from Lines, set the Options to Board_Geometry / Design_Outline then window the imported bits and you should get a close shape on Board_Geometry / Design_Outline. Turn off or delete the Assembly_Details layer and then use ZCopy to make the Route_Keepin / Package Keepin based on the Design_Outline.
