  3. How to view only test points?
  • Views 13745
SteveDeeds
SteveDeeds over 5 years ago
I'm auditing a .brd file for testability created in Allegro PCB Designer 17.2.  Is there a way I can view only the test points?  The reference designators all start with TP.
Steve
  • steve
    steve over 5 years ago
    If the testpoints were added using testprep or the automatic testpoint functionality inside PCB editor then the testpoints are labelled using the class/subclass Manufacture/Probe_Top otr Probe_Bottom so if you just turn on that layer that may should you what you need,
