  3. Errror simulating IR2110 with pspice (overflow)
  • Views 14253
rdpdo
rdpdo over 5 years ago
When I use the model pspice for the IR2110 for a full bridge I got overflow error. Does someone have a solution to this problem ?
I tried a lot of tweak with the solver, try to use initial condition on various capacitor... But no found solution !
Thanks a lot !
Regards.
  • AvengerThanos
    AvengerThanos over 5 years ago
    As suggested in the output window vary the value of the limit. The default, 0, specifies that there is no limit on data values. You can modify it to a large value, such as 1e12, to eliminate overflow errors, especially when using exponential sources. You can find options in PSpice - simulation profile - options - Analog advanced - general
