  3. convert psm file to bsm file (package to mechanical symbol...
  • Subscribers 166
  • Views 12909
convert psm file to bsm file (package to mechanical symbol)
ichliebedich
ichliebedich over 4 years ago
Hi all,
I downloaded the board outline data as an psm extension file,
but I want to use with mechanical symbol so I want to convert to bsm extension file.
so I tried to change the extension intentionally to bsm, but it couldn't import at the board
how can I convert to bsm or how can I modify the file?
regards
  • steve
    steve over 4 years ago
    Make sure none of the pins have any pin number text (Package Geometry / Pin_Number), if they do use Edit - Delete and remove just the text, then go to Setup - Design Parameters - Design tab and change the type from Package to Mechanical, then save and a filename.bsm will be written.
