  3. Reduce STEP File Size
  • Views 15172
pcbnagarajcid
pcbnagarajcid over 5 years ago
I'm exporting step file for a daughter card and the output file size is huge. I use File Export Step.
If I open in Soliudworks , the size again get increased by 3 times!!
Is there any way to reduce the file size of the STEP model of the board file?
Appreciate the help!
Nagaraj.
  • redwire
    redwire over 5 years ago
    Not really with STEP.  In fact if you use the 3D viewer STEP export the file sizes can easily each several hundred megabytes!
    If you want a small file, try exporting the BDF,LDF file instead and import using Solidworks Circuitworks instead.
