  3. Back annotating from Allegro PCB to OrCAD Capture with adding...
  • Subscribers 166
  • Views 11483
Back annotating from Allegro PCB to OrCAD Capture with adding the parts (SPB17.4)
ichliebedich
ichliebedich over 4 years ago
Hi All,
I need to add new DECAP on my PCB Board
so I used the Logic - Part Logic menu to add the new DECAP directly
and then, I assigned the GND and VCC net to my new DECAP parts
parts was assigned new Reference (Refdes) as well
So I tried to Design Sync to my OrCAD Capture to update the logical symbols on the Schematic
But I don't know how to add the my new symbols to OrCAD Capture Schematic,
How to update my new symbols to the Capture?
regards,
  • steve
    steve over 4 years ago
    You can't. Part Logic is used in a flow without having a schematic at the front end. Part and Net Logic allow you to add parts and nets inside Allegro. If you have a schematic you MUST makes the changes in the schematic then Design Sync into the PCB which will bring in the parts and nets. You can only Design Sync pin swaps, constraints and refdes renames.....
