  3. OrCAD or Allegro PCB 17.2 version Assign Color, Deassign...
  • Subscribers 166
  • Views 13554
OrCAD or Allegro PCB 17.2 version Assign Color, Deassign Color bug
ichliebedich
ichliebedich over 5 years ago
Hi all,
the assigning color was worked on 16.6 version
RMB - Assign color after select a pin!
and it could de-assign color with the "Dehighlight" command !
but it can't run on 17.2 version
Is there any good idea to de-assign for sigle pin color which I assigned color?
  • steve
    steve over 5 years ago
    manually Invoke the Dehighlight command (Display De-Highlight) and in the Options pane uncheck the box for retain objects custom color) then right click - Done. Now you can use the RMB Assign Color and RMB Dehighlight.
