  3. Skipping pins in footprint only
  • Views 10692
cabboud
cabboud over 4 years ago
If I need to delete the even numbered pins in a footprint while leaving the schematic symbol unchanged, how would I do that?
I have a high voltage application with large copper clearances, and I need to use an existing connector.  To get the clearances, I need to remove every other pin.
What I think I need is to replace each even numbered padstack with one with zero copper and zero through-hole diameter.  Does a dummy padstack like this already exist?
When I just edit the footprint (.dra) to delete pins, I get netlist errors because the footprint no longer matches the schematic symbol (obviously).
I'm using OrCAD 17.2 PCB Editor
