  3. team design ( partitioning the design )
  • Views 12738
archive over 20 years ago
how can i partition a design so that other designer can work with my design and help finish it in a short period of time?
currently, i am experimenting the journal that is created when you are working...
suddenly, it did not work as what i expected...
any help is highly appreciated.
Originally posted in cdnusers.org by frisco
    The 15.5 release will support design partitioning, but until then you have to manually manage this. To transfer the data from other designs into the master design, you can export, then import clip files (sub-drawings) in Allegro PCB Editor.
    If you are using the Allegro PCB Router (SPECCTRA), SourceLink Solution 11099366 will be helpful. I'll warn you now though, the illustrations needs to be improved, but you should be able to follow the detailed steps. I hope this helps!
    Originally posted in cdnusers.org by Padmin
