  3. Part Padstack on wrong layer / bonding / Flex zones
  • Views 11695
Yannick74
Yannick74 over 4 years ago
Cadence 17.2.
I'm using a library BB-via defined with only one layer (Layer = BONDS, just below TOP) and this is a connect pin of a part.
NB : I'm using this trick 'cos I can't use the Allegro Bonding feature since it is limited to 100 bonds with the std Allegro PCB editor package.
type: Blind/Buried Via
Hole data size = 0.0000
Design layer pads
Layer: BEGIN LAYER = DEFAULT INTERNAL  = END LAYER  = ADJACENT LAYER  = None
Pad
Geometry
Width
Height
X offset
Y offset
Regular
None
Thermal
None
Anti
None
Keep Out
None
Layer: BONDS
Pad
Geometry
Width
Height
X offset
Y offset
Regular
Square
0.0850
0.0850
0.0000
0.0000
Thermal
None
Anti
None
Keep Out
None
In the package, info on pin is correctly defined on BONDS layer.
info on pin:
pin number: 120
Padstack name:   BP_SQR_0-085
Usage:           Bbvia
padstack defined only on BONDS
When I put the part in the PCB design, the pad is swapped onto the BOTTOM layer ????
info on pin:
  pin number: U1.120
  pin name:     BANDGAP
  pinuse:       UNSPEC
  Zone name:    PCB_P1
  location-xy:  (64.5250 43.1875)
  Part of net:       N473817_HALF-SIDE0_ADC
  Number of connections: 0
  Reference padstack name:   BP_SQR_0-085
  Usage:           Bbvia
  padstack defined only on BOTTOM
  pin is EXPLODED from symbol
  padstack rotation:   270.000  degrees
  Attached text:
   class      = PACKAGE GEOMETRY
   subclass   = PIN_NUMBER
   value      = 120
Properties attached to symbol pin
    CLIP_DRAWING      = CLIP_1
When I edit this padstack design, the padstack is correctly defined on BONDS layer, as in the library padstack put in the part.
=> there is clearly an issue there.
I did several trials withiout any success:
- db check
- delete part, repackaging, replace part
- update symbol, with and w/o 'Update symbol padstacks from library'
NB : I'm using also the Flex zones, but BONDS layer is enabled on the zone I place this part.
  • Yannick74
    It seems this is correlated with the flex stackup : when I place the part outside the Flex zone, the padstacks are OK (defined on BONDS layer). When I put the part in the Flex zone I want, the padstack are automatically changed to BOTTOM layer.
    Is there any help (I didn't find anything) on how Allegro changes the pads layer automatically and is there a way to disable that feature. ?
