  3. A systemsi error
  • Views 10350
A systemsi error
shu999
shu999 over 4 years ago
Hi Dear,I am using SYSTEMSI to simulate the TI 6000 SRIO ,when i take the Ti's ibis-ami model  into the project,the soft stoped and  output this:
INFO: compiling tx 'Tx1' ami line =
'(ami (D:\000SIM2\all_connect\6657tx_ibis_ami\librincewind_40nm_tx.dll (rincewind_AMI_TX (Reserved_Parameters (Ignore_Bits 0 ) (Max_Init_Aggressors 3 ) (Init_Returns_Impulse True ) (GetWave_Exists False ) (Use_Init_Output True ) (Tx_DCD 4e-12 ) ) (Model_Specific (swingCode 15 ) (pre1 0 ) (post1 0 ) (corner 'n_0p90_1p50_027_nomR' ) ) ) ) )'
INFO: processing ami model 'Tx1:D:\000SIM2\all_connect\6657tx_ibis_ami\librincewind_40nm_tx.dll'
INFO: ami model line =
'(D:\000SIM2\all_connect\6657tx_ibis_ami\librincewind_40nm_tx.dll (rincewind_AMI_TX (Reserved_Parameters (Ignore_Bits 0 ) (Max_Init_Aggressors 3 ) (Init_Returns_Impulse True ) (GetWave_Exists False ) (Use_Init_Output True ) (Tx_DCD 4e-12 ) ) (Model_Specific (swingCode 15 ) (pre1 0 ) (post1 0 ) (corner 'n_0p90_1p50_027_nomR' ) ) ) )'
ABORT: Unable to open ami dll; tried two extensions 'D:\000SIM2\all_connect\6657tx_ibis_ami\librincewind_40nm_tx.dll.dll' and 'D:\000SIM2\all_connect\6657tx_ibis_ami\librincewind_40nm_tx.dll.so'
ABORT: You may be combining 64 bit engine/32 bit ami model or 32 bit engine/64 bit ami model
INFO: compiling rx 'Rx1' ami line =
'(ami (D:\000SIM2\all_connect\6657rx_ibis_ami\librincewind_40nm_rx.dll (rincewind_AMI_RX (Reserved_Parameters (Ignore_Bits 10000 ) (Max_Init_Aggressors 3 ) (Init_Returns_Impulse True ) (GetWave_Exists True ) (Use_Init_Output True ) ) (Model_Specific (corner 'n_0p90_1p50_027_nomR' ) (CDR_phase -1 ) (DLLid 'ti_rincewind_40nm_ami_RX' ) (RX_jitter_DCD 4e-12 ) (RX_jitter_RJ 0.8E-12 ) (anlg_eql_gaincode -1 ) (anlg_eql_zerocode 0 ) (anlg_eql_gainboost 0 ) ) ) ) )'
INFO: processing ami model 'Rx1:D:\000SIM2\all_connect\6657rx_ibis_ami\librincewind_40nm_rx.dll'
'(D:\000SIM2\all_connect\6657rx_ibis_ami\librincewind_40nm_rx.dll (rincewind_AMI_RX (Reserved_Parameters (Ignore_Bits 10000 ) (Max_Init_Aggressors 3 ) (Init_Returns_Impulse True ) (GetWave_Exists True ) (Use_Init_Output True ) ) (Model_Specific (corner 'n_0p90_1p50_027_nomR' ) (CDR_phase -1 ) (DLLid 'ti_rincewind_40nm_ami_RX' ) (RX_jitter_DCD 4e-12 ) (RX_jitter_RJ 0.8E-12 ) (anlg_eql_gaincode -1 ) (anlg_eql_zerocode 0 ) (anlg_eql_gainboost 0 ) ) ) )'
ABORT: Unable to open ami dll; tried two extensions 'D:\000SIM2\all_connect\6657rx_ibis_ami\librincewind_40nm_rx.dll.dll' and 'D:\000SIM2\all_connect\6657rx_ibis_ami\librincewind_40nm_rx.dll.so'
How could I take this off,and get simulate success?thank you very much!
