  3. Cadence PCB Editor 17.4 will not open SolidWorks DXF as...
  • Views 13152
Cadence PCB Editor 17.4 will not open SolidWorks DXF as Design Outline
Shqiprim
Shqiprim over 5 years ago
Hey everyone, I am trying to use the DXF generated from SolidWorks as board geometry design outline but the PCB editor throws errors and won\t accept the DXF file!
In contrary, if I try exporting the DXF from fusion 360 it will work!
  • steve
    steve over 5 years ago
    Could be that the DXF from Solidworks does not form a closed polyline (shape). Design_Outline requires the objects to be a closed shape. Try importing into a different subclass (say Assembly_Notes) and if that works you can use Shape - Compose Shape (or Create Shape from Lines in OrCAD), set the Options pane to Board Geometry/Design_Outline and window the imported outline. It will then convert to a Design_Oultine,
