  3. Capture CIS relational database buggy?
  • Views 10689
eddoh
eddoh over 4 years ago
Well,
I spent some time to understand how to make it work and I think there is a bug there.
I wanted to link a Diodes table to a procurement table using two fields instead of just the "Part Number" one (reason being that I wanted to have details for a double key relationship - involving not only the Part Number but also the Package.)
So I created a new FKEY field both in the Diodes table and the Procurement tables, set to the same value and in the CIS configration>Setup>Relational database, I set up the following
  • Primary key table name: Diodes
  • Primary key: FKEY
  • Relational table: Procurement
I expected to see the records matching the same FKEY fields, but it does not seem to work.
Looks like the link implemented in the database is always Diodes:Part number -> Procurement:FKEY instead of  Diodes:FKEY-> Procurement:FKEY
In particular here is the test table
Diode:FKEY Diode:Part Number Procurmn:FKEY Procurmn:Part Number Record linked in relation table?
XX YY XX ZZ No (expected yes)
AA XX BB XX No
CC XX XX DD Yes (expected no)
XX EE FF XX No
 think this is a bug, imho. Binding relationship to Part Number of the "Primary key table name" table is actually quite limiting, as you cannot play around tweaking the Part Number field of the main CIS database tables.
Hoping that I got everything right of course. Apologies in advance if I got everything wrong.
Cheers
