  3. Default symbol name character limit
  • Subscribers 163
  • Views 15265
archive over 20 years ago
Does anyone know what the default character limit is for a symbol name? (.psm or .dra) Can this be changed? Where do you make the change?
Lots of questions, I know but really appreciate the help.
Originally posted in cdnusers.org by paul481
    You should find SourceLink solution 11072282 - Length limitation and acceptable characters for use in netlists and Allegro elements, helpful.
    Also, you can set the variable 'allegro_long_package_name' to increase the limits to 256 characters, but this variable must be set on any system using longer file names. You will have to edit your local ENV file and add the following line to set the variable (then restart Allegro).
    set allegro_long_package_name
    Make sure you add the line 'above' the User Preferences section.
    Hope this helps!
    Originally posted in cdnusers.org by Padmin
