  3. Netlist Error
  • Views 10857
Netlist Error
DimaBA
DimaBA over 4 years ago
Hello
In schematic I enabled make swap to FPGA.
I got design with swapped lines in FPGA and I make back annotate.
And after it when I tried to run netlist, I got next error notification:
ERROR(SPCODD-409): Error at line 65 while loading the C:\Project\1579\Schematic\Temp\netlist\pstxnet.dat file. Unable to create the following new pin instance, IO_4A_AB16/DIFFIO_TX_B29P/DQ4B, as the pin definition was not found.
      Reference Designator: P1.
      Schematic Instance: @\ba1579-sd1-p1_01\.top_level(sch_1):bl2@\ba1579-sd1-p1_01\.fpga1_main(sch_1):bl42@\ba1579-sd1-p1_01\.fpga1_page5(sch_1):ins15430831@\ba1579-sd1-d19\.\5cgxfc4cu19_7b.normal\(chips) (MODULE: FPGA1_PAGE5; PART: 5CGXFC4CU19_7).
      Check the symbol and ensure that the pin definition is consistent.
ERROR(SPCODD-383): Error at line 65 in file C:\Project\1579\Schematic\Temp\netlist\pstxnet.dat. Unable to load the net list file. Run Packager-XL (Export - Physical) again.
Can you advise how can I resolve it?
