  3. How to highlight component based on degree?
  • Views 12082
wecan
wecan over 5 years ago
Hi All
Any methods to highlight  the component based on degree any commands or skill files available  please share me. Thank you.
  • steve
    steve over 5 years ago
    Yes - Try the Find by Query command, Look in the Find pane and choose Find by Query - double click Symbols in the left column which moves this to the Fields column, now double click Rotation Angle which moves this to the Filters column, Double click Rotation Angle = * and you can either choose the angle you want. Once set the list at the bottom will populate with all the symbols at that rotation angle. You can either select each one by one in the list or choose the square between rows and columns and all will be selected and highlighted in the board.
